Discuz! Database Error
(1064) You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ')' at line 1
select uid, groupid from common_member where uid in()
PHP Debug
No.FileLineCode
1forum.php67require(%s)
2source/module/forum/forum_viewthread.php180showmessagenoperm(%s, %s)
3source/function/function_forum.php405showmessage(%s, %s, Array, Array, %d)
4source/function/function_core.php1419dshowmessage(%s, %s, Array, Array, %d)
5source/function/function_message.php237include(%s)
6data/template/33_30_common_showmessage.tpl.php1hookscriptoutput(%s)
7source/function/function_core.php1211hookscript(%s, %s, %s, Array)
8source/function/function_core.php1170call_user_func(Array, Array)
9plugin_nciaer_hiddenreplies->viewthread_nciaer_output(Array)
10source/plugin/nciaer_hiddenreplies/hook.class.php39discuz_database::fetch_all(%s)
11source/class/discuz/discuz_database.php101discuz_database::query(%s, Array, false, false)
12source/class/discuz/discuz_database.php137db_driver_mysql->query(%s, false, false)
13source/class/db/db_driver_mysql.php152db_driver_mysql->halt(%s, %d, %s)
14source/class/db/db_driver_mysql.php223break()
www.nlinechina.com 已经将此出错信息详细记录, 由此给您带来的访问不便我们深感歉意.
